Options if timing is one tooth off after cranking
Old 07-30-2011, 07:49 AM
jly2258's Avatar
Default Options if timing is one tooth off after cranking
My passenger side cam timing mark is one tooth towards passenger side after setting the timing on the 300M. Crank and driver side cam marks still there. What are my options? (I have not loosened either cam bolt but moved both cam marks by hand) Thanks!
Old 07-30-2011, 09:36 AM
if its of then u did not set it up right re do it the marks need to be between the 2 little dots any where in there and u are good
Old 07-30-2011, 08:04 PM
jly2258's Avatar
Thank you for quick reply. You were right and I redid until now it should be good to go. Correct tightening of the tensioner seemed to be my problem. Took me a while to figure that out.
Old 07-31-2011, 06:36 PM
jly2258's Avatar
Default Why is AC pulley grinding on its tensioner housing?!
Got the 2000 300m started after timing belt/water pump, thermostat, drivebelts replacement job, started it up and got a rattling noise and noticed the ac pulley looked loose (it wasn't). Stopped the car and the pulley is pulling up against the housing and grinding metal on metal? any ideas? Thank you!
Old 08-06-2011, 01:09 AM
anwaypasible's Avatar
new pulley is $10 at the junkyard no?
Old 08-06-2011, 07:15 AM
jly2258's Avatar
17 or so at autozone is what I ended up doing. Thanks.
tucsonflash
02-07-2013 03:21 PM
jly2258
07-28-2011 11:07 PM
cchpounder
05-17-2011 11:16 PM
BMFSRT8
03-03-2006 02:03 PM
Rico
11-14-2005 07:17 PM
Quick Reply: Options if timing is one tooth off after cranking
