2003 brake light fuse keeps blowing
03 Chrysler sebring lx sedan fuse for brake lights keeps blowing put new brake switch in & sill blowing fuse. Changed light bulbs & still no lights. checked wiring going to lights & they look good. What could be making my fuse to blow. please help can't drive with no brake lights
I have looked at wiring from fuse to bulb & it looks good. I've had 2 people that were car mechanic & they can't find short. Now my stereo is messing up A/C control will set 4 cooled then after working 4 awhile will start 2 blow hot my front lights & dash keep dimming every once in awhile. Another thing is it seems to use more fuel. Someone told me the car needs new brain. Y can't cars be like the older ones simple 2 have running & work on?
Y'know, if you prefer the older cars, there's nothing stopping you from going out and buying one. There are lots of them out there: no computers, no fuel injection, no airbags, no antilock brakes, completely mechanical and analog. My granddad's '54 Mercury was a perfect example. 6 volt electrical system and a radio that used vacuum tubes.
In the meantime, you might want to go somewhere that has a DRB III and have them search for error codes. Your body computer might be having issues.
a short to ground will not show any codes The issue when it blows the fuse needs to be present when they look for it our U let them have it and drive it around until the short is touching the ground to which they can find it then .
