2007 sebring 2.4 po455 code help requested
Old 06-23-2019, 05:15 PM
westernreach's Avatar
Default 2007 sebring 2.4 po455 code help requested
hello,
my daughter's 2007 sebring has the check engine light on. she told me it came on a few weeks ago for 2 days, car only stalled twice during that period and then on the 3rd day it went out. 3 weeks later it came back on, code is po455 "Evaporative Emission System Leak Detected Gross Leak/No Flow"
Any idea on where to start looking?
thank you in advance
Old 06-23-2019, 07:13 PM
REBEL59's Avatar
Start with checking that the GAS CAP is on tight. Then start in the LR corner looking at EVAP canister and hoses being cracked or broken.
Old 06-23-2019, 11:05 PM
thank you , i did check gas cap and it is tight, i will start looking underneath when it stops raining here. thanks again.
Old 06-24-2019, 06:18 PM
BiliTheAxe's Avatar
I had that once in the past, and even though the cap looked good, the code went away when I replaced the cap with a new one.
Old 08-05-2019, 12:34 PM
boatmoter's Avatar
if it's not the fuel cap loose, and you don't see a broken hose any where from front to the tank, then you may need to have the evap system smoked to find the leak
corvairbob
05-28-2022 05:06 PM
wburger1
12-17-2018 11:27 AM
redfox69
05-26-2015 12:30 PM
02 Limited Conv
03-03-2013 12:59 AM
swin555
12-06-2008 03:29 PM
Quick Reply: 2007 sebring 2.4 po455 code help requested
