2006 300c remote key programming
Old 01-24-2010, 09:20 AM
joehajos's Avatar
Default 2006 300c remote key programming
Do I need the dealer to program a new remote if I only have 1 ?
Old 01-24-2010, 08:01 PM
yes need two if U want to do it yourself
Old 02-10-2010, 05:37 PM
supra92's Avatar
to program a new key yes you need 2 keys, with one is not possible and you have to go to the dealer
to program a remote you only need to have one remote
switch ignition on
using a programmed remote press and hold the UNLOCK for 10 seconds
after holding the remote unlock for 4 seconds press the the panic button and release together
if the vehicle horn makes a noise you are in program mode
now press any button on the new remotes, you can program 1 2 or 3 more remotes
switch the ignition off and wait 32 seconds ,horn will beep again
you are finish test your remotes
Old 02-10-2010, 08:18 PM
hey supra b4 u give out info please check what u say to be true.
The keys for the 06 300 is a key and remote in one unit not separate like older cars.
So back to what I said u will need 2 working keys to program a new one.
ma210
10-01-2010 09:56 PM
Eastky
02-22-2010 10:50 PM
ymitchell
10-26-2009 12:44 AM
tfgib
05-12-2007 07:58 PM
klaipedos_briedis
04-13-2007 01:06 PM
Quick Reply: 2006 300c remote key programming
