I have been experiencing a vibration in the front end when braking. The higher the speed the more violent the shaking. I thought it was the front brakes but it turned out that the motor mounts are the culprit and need to be replaced. How can it be - 37000 miles ????? I have owned numerous cars in my lifetime and never have I had to replace motor mounts. The question now is it covered under my "LIfetime Powertrain Limited Warranty"?
humm motor mounts do not cause vibrations when breaking only when the load of the engine is changed u have warped rotors.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep KKeller608@aol.com http://kevinsmobilerepair.com
Due to the ever increasing amount of lead-Based Material found in the right side component of adult footwear, there is currently no permanent repair for this issue.
Now, In all Honesty.... If your mounts were bad enough to cause a Vibration, You would have "Trashed" the CV axles Years Ago........
I second the Warped Rotor Theory.
__________________ Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Your info is very helpful. The vehicle is at the Chrysler Dealer and undergoing a Diagnostic Evaluation. I should know by tomorrow what the problem is.
Well it turns out that the brakes were causing the vibration when braking. Now the problem still remains that the motor mounts are worn. The engine has considerable movement when placing the trans in drive or reverse. I would say that the engine moves a good 4" front to back. The Chrysler dealer/mechanic said "the motor mounts are fine, nothing wrong with them". Any thoughts on this?
the pac is known for mount issues with out seeing them first hand no one on here can tell u
__________________
