rear window defrost not working
the rear window defrost on my 2004 pacifica stopped working, worked fine last winter. When you push the button, the light on the button turns on and you can hear a click like a relay turning on comming from both front doors. The rear heat grid is not damaged and i put a meter the posts on either side and the ground is good, not getting power to the blue w/ white tracer wire on the driver side post. Checked the fuse box, all the fuses are good, doesn't seem like there is one just for the rear defrost, and i couldn't find the location of the relay. Don't know why i hear a clicking in the doors, no reason to have the rear defrost relay inside the front doors.
RE: rear window defrost not working
yadog
01-03-2014 08:34 PM
Comrade
04-08-2010 09:02 PM
