turn signal+water+cold=double speed
Old Jan 17, 2012 | 10:34 AM
desperado's Avatar
Default turn signal+water+cold=double speed
Hi.
for some reason, the right side turn signal will click at twice the speed after the car is washed and left outside in freezing weather.
It's happened once right after a carwash, and recently, I had the car fixed (a 5700$ fender bender) and they hand washed it then left it outside.
For about a week, it would click at double speed until the car had been running for about 20 minutes. It's now back to nornal.
I'm assuming there is ice forming that bridges some connection or circuit? If so, where would this happen?
all the lights work fine.
Old Jan 17, 2012 | 11:27 AM
bulb or wire issue take it back to who fixed the fender issue
Old Jan 17, 2012 | 02:55 PM
desperado's Avatar
This was happening before the repair.
Old Jan 20, 2012 | 07:58 AM
phottomatt's Avatar
A fast blinker means a burned out bulb (or wiring), it's the vehicles way of telling you there is something wrong because you can't actually see the lights when they operate. Have someone stand outside and watch the blinker lights front and rear to see if one is burned out.
Old Jan 21, 2012 | 08:03 AM
desperado's Avatar
please read the original question, last line: all lights work fine.
there is no burnt light.
from what I've been able to read, it might be excess humidity (read : water) messing with the ground wire of the turn signal in the tail light.
what's odd is that it messes with it only if frozen. once it warms up, it's fine.
I'll have to open it up.
Old Jan 21, 2012 | 11:12 AM
Time line from first post
U had a fender bender
Had some one fix it
They washed car
Then u had this issue
According to you in post # 2 This was an issue b4 they fixed the fender is that correct or am I missing something?
If there was not an issue b4 the repair of the fender bender then this was caused by the accident and or the people who did the repair.
If it was an issue b4 all of that then the washing of the car and fender bender repair is irrelevant to any of the currant probs.
Clear some stuff up.
Old Jan 21, 2012 | 11:53 AM
desperado's Avatar
timeline:
1. washed car in summer : no issue.
2. washed car in early winter: issue.
3. had accident. accident is irrelevant.
4. they fixed car. they washed car. they put car outside. it was cold: issue.
common denominators: water, cold.
as mentionned, the problem goes away (blinker slows down to normal) as the car warms up.
Old Jan 21, 2012 | 03:03 PM
desperado's Avatar
forgot to mention that it usually goes away by itself after a week or two. (I imagine it's the time it takes to dry/melt/evaporate completely)
fyi, just took out the back light housing, and it didn't look like it had any water infiltration. checked wiring while signal was on. everything seems good from that end.
Maybe it's the wiring inside the hood.
swittie
Nov 10, 2020 02:02 PM
GSKI
13
Sep 11, 2007 09:33 AM
alan
Jun 11, 2007 09:27 PM
evo8rcr
Jun 3, 2007 12:46 AM
pinecone
Aug 25, 2005 01:13 AM
