Traction Control light comes on
Old Mar 10, 2009 | 05:59 AM
Hamilton's Avatar
Default Traction Control light comes on
I am having a problem with my traction control light and abs light coming on, combined with a grinding noise around my left wheel when turning right.
Took to garage and computer said sensor needed replacing. This was done, but grinding noise is still there occasionally and a week later light is coming back on intermittently.
Any ideas what the problem might be?
Cheers
Old Mar 10, 2009 | 10:28 AM
troymaclure's Avatar
grinding is first sign of a wheel bearing , it might be that the sensor replaced was an abs sensor , this is getting dirty again with metallic grindings, get it up on a hoist or jack and check the wheel by seeing if it will move when you grasp it from the bottom of the tire by shoving it back and forth from top to bottom , if it does get the bearing changed out and spray the abs sensor with electrical cleaner .
Old Mar 10, 2009 | 03:37 PM
Merlin's Avatar
I would check the ABS ring on the driveshaft, The most common issue I see with this fault is when the ring cracks and becomes loose on the CV joint. With the grinding noise I suspect this could be just the traction control kicking in due to the incorrect speed signal received from the ABS sensor.
Old Mar 11, 2009 | 04:55 AM
Hamilton's Avatar
Thanks guys. I'll have it checked out again.
billbon8
Aug 5, 2022 12:25 PM
dalexx10
May 31, 2021 08:51 PM
Mark Houghton
Apr 22, 2014 10:20 AM
sangelos
Aug 10, 2012 04:57 PM
F150
Mar 15, 2007 12:13 AM
