power steering
Old Feb 12, 2009 | 08:50 PM
jakemary's Avatar
Default power steering
my 2001 pt steering is hard to steer. 130,000 miles on it. any ideas?
Old Feb 12, 2009 | 10:13 PM
Could be several things. Check the fluid level and the tire pressure level. Check the drive belt tension. Those are cheap and easy to check.
Could be ball joints need attention, either lube or replace.
Might be a weak pump or internal leak in the system. That requires some professional diagnosis with a pressure test.
Hope that helps.
Old Mar 6, 2009 | 06:33 PM
jakemary's Avatar
bad news from the dealer 2500.00 to fix the powersteering.
Old Mar 6, 2009 | 06:40 PM
OW!! Might want to check around to see if you can get it done cheaper elsewhere.
Old Mar 6, 2009 | 11:07 PM
Al B's Avatar
yup, that seems OUT-RAGOUS!
Old Mar 7, 2009 | 08:34 AM
jakemary's Avatar
the dealer said they would give my $500.00 for a trade in Hahaha. the car is clean. 131000 miles on it. they also said the lines are leaking but my fluid level is fine.
Old Mar 7, 2009 | 08:55 AM
xfire04's Avatar
take it to a independent shop an see what they say
Victor L
Jan 12, 2014 08:38 AM
Lanny393
Nov 2, 2006 01:44 PM
rickey1172
Oct 18, 2006 03:03 AM
allenl44
Sep 16, 2006 12:21 PM
allenl44
