motor tap
Old Jan 21, 2012 | 06:44 AM
merrellj's Avatar
Default motor tap
I have a 2000 Town and Country, 3.8 engine. When the engine is cold there is a tap, sounds like from the top, it only does this when the motor is cold, once is war there is no noise. What is causing this?
Old Jan 21, 2012 | 07:51 AM
low oil or lifters not having oil up top its basically a lifter not being pumped up.
Old Jan 21, 2012 | 08:12 AM
merrellj's Avatar
oil level is good, so a new oil pump?
Old Jan 21, 2012 | 11:06 AM
Did i say anything about an oil pump??
AN oil pump does not get batter as it warms up
U have a lifter issue or an oil filter not allowing oil to stay at the top of the engine
Old Jan 21, 2012 | 11:18 AM
merrellj's Avatar
how would a oil filter get better as the motor warms up
Old Jan 21, 2012 | 12:20 PM
pestilance's Avatar
Wynns Hydraulic Valve Lifter Treatment
throw in a bottle of that,that will help cure it.will clean all the oil ways
Old Jan 21, 2012 | 01:04 PM
booke23's Avatar
They don't. It has to do with the fact that alot of cheap aftermarket oil filters have an ineffective anti drain valve or don't have one at all. This allows oil to drain out of the filter and the top end of the engine back to the sump. If you are using mopar filters or a good quality aftermarket filter then this usually does not happen.
Old Jan 21, 2012 | 04:12 PM
This would be the 3rd time I have pointed out this is a lifter prob and things like cheap oil filter low oil or a bad lifter could be the cause to this issue Please read the info I have given and think about what U ask or say b4 U post it.
Thanks brroke23 I hate repeating myself more then 2x
elpaso
Cirrus & Breeze
Aug 8, 2011 05:30 PM
Vanman
15
Jul 17, 2009 06:17 PM
94 Octane
Nov 10, 2005 11:39 AM
aleatha_0814
May 11, 2005 01:58 AM
redriderbob
Dec 6, 2004 01:40 PM
