2006 Theft alarm problem
2006 Town & Country Touring, all the doors lock with the key fob but the theft alarm does not arm. The doors also lock with the driver and passenger door lock switch but the alarm does not arm. I know the alarm is not arming because the arming light on the instrument panel does not light at all and I've tested the doors with them locked and opened them via an open window and no alarm, also tried from inside the van with the windows up and no alarm. Any ideas?
- marriages sometimes lead to separation and even divorce resulting in acrimony and refusing to work together
- divorcing a brain from a battery by can have the same effect, acrimonious divorce needs a priest capable of reconciliation
EEPROMS default to dumb essential basics........... now where did I put that priest !
- curious minds, and curious marriages
- you need to re-marry [sync] the keyfob and the vehicle again to provide protection
- see this thread here and ask more questions when you've read it
When your battery was totally flat or you replaced the car battery the previously harmoniously married KEYFOB and the car protection suffered an acrimonious divorce, so bad that they no longer trust each other or even talk to each other. You need a reconciliation between them.
This worked for me, it was permanent and I've had no problems since :
- take the NEG off the battery for whatever but at least a half hour
- replace the NEG on the battery
- turn the key to the start POS but do not START the engine
- - - the PUTER will read all BUS's and door locks, and do all checks, you will hear lots of clicks and checks
- when the checks stop lock and unlock the doors FROM the FOB / Remote several times
- - - this will re-marry the KEYFOB and the PUTER
- start the car, while it warms up re-set the missing settings from the radio, roof display electric seat adjustments etc
- stop the engine and lock in the usual way with the KEYFOB
NOTE01: Others have advised not to use the internal PANIC lock all doors feature if you have one, I confess I've never had a problem with this.
Last edited by QinteQ; 03-13-2013 at 06:39 PM. Reason: oooooooooooop's > insert the word remote ? American cousins!
I also have got alarm lock installed by locksmith dallas near me. It's working fine with the car and in future if any problem arises, will definitely call them again for lock related issues.
The_jakester
12-02-2010 08:55 PM
irdaneel
04-06-2008 06:46 PM
susan1963
12-06-2005 02:03 PM
