Sponsored by:
Sponsored by:
FCM Removal
Old 03-08-2015, 06:49 PM
drttrkrcr8d's Avatar
Default FCM Removal
Can anyone explain to me how to remove the FCM on a 2001 town and country?
Old 03-09-2015, 11:53 PM
unscrew the 4 screws and remove it
Old 03-10-2015, 03:09 AM
Vmaxxer's Avatar
I am curious what a FCM is?
Old 03-10-2015, 07:31 AM
Front control module, little but important micro controller based module under IPM. Controls lights, wipers, horn, fans, demister etc. It's essentially an information exchange between the CAN network and the IPM.
Old 03-10-2015, 09:40 AM
Yep got it tried 2 different fcm and still have same issue with headlights gonna do back and switch if that don't work I'm at a loss
Old 03-10-2015, 10:39 AM
- both the FCM and the IPM [Power Distribution Centre] control exactly the same things- either could be the fault
I'd start by eliminating the IPM [which you can do] not the FCM [which I think needs programming to the VIN] You have had 15 years of acid, salt, rain, and $hite in and under the IPM, its wiring and plug pins and connectors - Best of luck.
Old 03-11-2015, 03:13 PM
Is this an issue with the front headlights not working. If it is there is possibly a break in the wiring between IPM/FCM and headlight. I had this fault to nearside light and found a bad repair bypass wire bridging the harness so I investigated and found break in harness where it was rubbing a plastic bit of under shield, front left of engine compartment.
Old 03-12-2015, 01:34 PM
Was your light problem just the driver light not working or one light not working and switching sides when going from low to high beams but only having one light either way?
Old 03-12-2015, 03:49 PM
Just the nearside headlight/full beam. Have a check on You Tube on this issue think I found a video that indicates this is a known fault area.
tbird2340
08-09-2011 09:57 PM
Rick99
13
11-12-2009 02:34 PM
Johnny B
04-20-2006 07:40 PM
Dusto
10-03-2005 06:17 PM
ezgoinn
07-29-2005 11:44 PM
Quick Reply: FCM Removal
