Sponsored by:
Sponsored by:
Heater problem
Old 01-28-2015, 03:14 PM
briarwood's Avatar
Default Heater problem
2004 T&C 3.3 engine Heat gauge goes up half way and will have hot heat.Drive van and heat slowly gets cooler and cooler and then will start getting hot again,drive a little farther and will start getting cool again. Will start getting hot heat a little farther down the road.Heat gauge will still be half way all the time.Any one have any ideas
Old 01-28-2015, 03:23 PM
Leedsman's Avatar
Thermostat jammed open is the usual one, esp if you've had blocked radiator problems. The see-sawing temp. is the giveaway. See my posting a few lines down.
Leedsman.
Old 01-28-2015, 05:16 PM
broken on the tang that holds the spring in place common issue
Old 01-28-2015, 05:43 PM
briarwood's Avatar
Hey Chrysler Tech there was a pic of something and now it's gone.So what is it and where is it located
LynnieS
09-13-2013 01:04 AM
skywalker
01-22-2011 08:19 AM
Trevor Barnard
12-29-2008 06:10 AM
madman
06-20-2008 08:35 AM
timmyv
01-28-2007 08:03 PM
Quick Reply: Heater problem
