Upper and lower ball joints
Old Apr 2, 2008 | 02:13 PM
The BIG STEAK's Avatar
Default Upper and lower ball joints
Are upper and lower ball joints replaceable on the 97 cirrus without changing the whole upper or lower arms? Could also use some outer tie rod end too. How do the inner tie rods hold up? While I'm asking, how hard is it to change the front wheel bearing/hub assy? I'm in need of one of those too.
STEAK
Old Apr 2, 2008 | 03:08 PM
moe's Avatar
moe
Default RE: Upper and lower ball joints
hey steak,you need to replace the whole control arm on the upper and lower!!,hub and bearing is not so easy either,heres how it bolts in as an assembly.better to get hub and bearing together.if not you'll need a press .heres goes
jimmy154
Dec 12, 2011 01:16 PM
mwstant
May 21, 2010 08:31 PM
Moparkyle
Apr 27, 2010 09:24 PM
jellyb30
Feb 17, 2009 02:41 PM
01SebringLXI
Apr 4, 2008 09:41 AM
