Codes: PO 112 and P1496
Old Aug 26, 2010 | 11:56 PM
didy's Avatar
Default Codes: PO 112 and P1496
Recently, my Chrysler Cirrus (1997) stalled. and I got my PCM replaced.
The check engine light was on before and after the replacement.
By checking the code, it comes out the following codes:
1. PO 112 Air intake temperature sensor
2. P1496 5 volt output too low
I am worrying that my new PCM will be burnt again with bad sensors or bad wiring that cause the error codes.
Is there anyone can offer me some suggestions how to check these problems or even fix them? Or, even just tell me if there is a possibility my new PCM will be burnt again due to reasons related to these error codes.
Thanks,
didy
Old Aug 27, 2010 | 06:34 PM
TNtech's Avatar
You need somone who knows their stuff to look at that. Any advice from me here would be electronic nerd talk. But I will tell you the most overlooked item on that 5V circuit is the A/C pressure transducer. It's also the last in line. Are you having intermittent running issues?
Old Aug 28, 2010 | 11:01 AM
didy's Avatar
Hi, TNtech,
Thanks for the answering.
Yes, I have an intermittent running issue. After started the engine, the car would just stopped running after I drive on the road in low speed. I can restart the engine. I noticed that when the check engine light was off right before the car stopped. It seems there is something loose. Another thing is, when I am at high speed, say, ~60 mph, the check engine light might also get a chance to be off for couple seconds. At that moment, my car would experience a shaking due to the engine or something changed. After that, the check engine light would come back on and the engine runs normally.
I will go to Chrysler dealer to sort out the potential problem. Just want to know a little bit more before talk to the technician.
Thanks,
Old Dec 21, 2010 | 11:21 AM
Donzwon's Avatar
Hey Didy, I have the same exact problem with my sebring. What did you do to fix your car.
Old Dec 21, 2010 | 11:28 AM
Donzwon's Avatar
Default Chrysler sebring codes 112 and 1496
Sorry Didy, Could you PLEASE tell me what you had to do to fix your car. Thanks very much in advance.
Old Dec 22, 2010 | 01:24 PM
didy's Avatar
Hi Donzwon,
After the question I asked few months ago. My car accidentally stopped running. I tool it to dealer and they fix it with changing a new engine computer. The part costs about four hundreds something, and the final price is about six hundreds something including the labor.
So, the guys in dealer told me that the check engine light was because of the failure of the engine computer. And, indeed, after I change that, the problem solved.
So, you might want to check your engine computer. And if you purchase an used one, it would be cheaper.
didy
Old Dec 23, 2010 | 09:10 AM
Donzwon's Avatar
Thanks Didy, You were very helpful.I will do that.
Old Dec 24, 2010 | 10:38 AM
TNtech's Avatar
Look, there are test procedures to go by for codes. Get a manual and do them. If you can't, let someone else diagnose it for you. It's not shameful to admit you can't do it on your own. Cars are nuts.
Jfizzle
Feb 22, 2020 04:37 PM
Newtonn
Jul 7, 2019 11:51 AM
RacingJunk
Jun 15, 2014 05:48 PM
RacingJunk
May 21, 2014 09:08 AM
3.3lxbluevan
Jul 15, 2010 05:48 PM
