Error codes
Old Jul 11, 2009 | 11:54 AM
2000 Intrepid's Avatar
Default Error codes
Hello all, new here & have a few ???
I just purchased a OBD2 code reader to find out why my check engine light was coming on.
I found 2 codes,
P0172 System too Rich (Bank 1)
P0404 EGR Flow CKT Range/Performance
It's a 2000 Intrepid 2.7 with just about 200k on her.
Should I change out the EGR Valve?
Will this also solve the too rich issue?
Old Jul 11, 2009 | 01:53 PM
The EGR problem may be a bad EGR valve, or it may be a bad EGR sensor or wiring.
The running rich problem could be many things:
O2 sensor
Evap purge solenoid
Throttle Position sensor
Manifold Absolute Pressure sensor
Engine Coolant Temperature sensor
Fuel pressure regulator
Engine computer
PCV valve
Exhaust system obstruction
others
Get the EGR problem solved, clear the codes and see if they come back. If so, start looking at the other things.
Old Jul 11, 2009 | 03:48 PM
Thanks for your reply dcotter0579
Old Feb 15, 2011 | 01:21 AM
HerbertGoodsell's Avatar
The error codes are disappearing from the environment as a programmer object-oriented programming language to replace them with modern exceptions. Exceptions have the advantage that they have been handled with explicit code blocks, separated from the rest of the code. Separation of code error handling logic normal makes programs easier to write and understand as a block of code error handling error can service any number of function calls.
Jfizzle
Feb 22, 2020 04:37 PM
kart45
Aug 18, 2010 09:21 AM
moorek
Aug 23, 2009 07:28 PM
aruninesgirl
Aug 18, 2009 08:55 AM
VanJockey
Apr 7, 2008 08:58 PM
