Code p0601 01, lhs
Code p0601 01, lhs
OK here the problem I'm not having any power problems that's I can tell no lights on the dash except check engine light and the only thing that's going on is eventually the car will start whining like transmission whining sound and it'll start shifting funny and slipping real bad and not wanting to move the only code that I'm pulling up of course I'm only using the key test is the 06 0.1 and from the all the other forms that I'm reading I should have a whole lot more symptoms and issues then what I'm having for it to be the PCM so what else could it be the shift solenoid neutral safety switch but I'm running out of ideas and options
Most likely the PCM, sometimes reflashing helps, have a look here:
Chrysler | Dodge | Plymouth | Engine Computers | ECU | ECM | PCM
Hopefully it helps
Michael
Hopefully it helps
Michael
thegrandvoyager2
10-18-2015 02:52 PM
stewartsoftware
04-23-2011 08:05 AM
