2000 Stratus - No panel lights other than idiot lights. BCM or Dimmer Switch Assembly
Old Mar 8, 2011 | 11:43 PM
Gknight's Avatar
Default 2000 Stratus - No panel lights other than idiot lights. BCM or Dimmer Switch Assembly
Hi all. I'm brand new here as I just bought a 2000 Stratus today. When it got dark I realized I have no lights in my panel anywhere other than idiot lights. I've heard alot of talk about BCM and even some about DImmer Switch assemblies. IT seems like most issues stem from BCM issues but I have no idea where this is or how to replace it. Any help would be appreciated. Thanks for the help!
Old Mar 9, 2011 | 12:14 AM
Gknight's Avatar
Default Maybe an easy fix?
I just looked at the fuse panel again and noticed that the Headlamp Relay is missing? COuld this disable my panel lights?
Old Mar 9, 2011 | 12:32 PM
TNtech's Avatar
Could be dimmer, cluster, BCM or junction block. I would advise you to pay someone some diagnostic time. You don't wanna go down this road blind.
Old Mar 10, 2011 | 02:40 PM
Gknight's Avatar
Default Been to the mechanic...
Found that it was burning out the #7(I think, or maybe #5? 20amp)Illum/Tail/Park fuse, Took to a mechanic. Did some testing felt it was the switch that has dimmer, wiper, lights, etc. Well he replaced that and now everything works...BUT now the fuse in the block literally melted down! So now it is going to the Stereo store the previous owner sent it to to install a stereo in the slim hope that they somehow wrired something wrong. I say slim because the stereo works fine with or without the fuse. So now I know 'm grounding out soemwhere and if it isn't the stereo I need to go to a new shop as this mechanic admits he's not very good with wiring. So $200 down and no joy yet. If you know any hints on ground outs in that area I'd be appreciative. Thanks again!
Old Mar 10, 2011 | 07:26 PM
Try here, you might get lucky:
http://www.the12volt.com/
morbert
Jul 18, 2015 10:00 AM
Vcor71
Oct 21, 2014 12:03 PM
Khalid
Dec 13, 2009 08:38 PM
dcoperator
Nov 27, 2008 03:18 PM
ladisgsx
Mar 4, 2008 02:43 PM
