Wire Colors On Infinity Acoustic 10 System?
Old Aug 29, 2006 | 11:33 PM
neuronyx's Avatar
Default Wire Colors On Infinity Acoustic 10 System?
Hello everyone,
First post here on Chrysler forums. I joined because I have an issue pertaining to the Infinity Acoustic 10 sound system installed in my Dodge 1996 Caravan. Recently I had one of the speakers in the passenger's side door die on me. So, I decided to replace it myself, seeing I have done speakers on other cars before without a problem. Now, once I removed the door paneling, I removed the speaker and found this module mounted to the speaker. I later discovered this module is a power booster, which essentially amplifies the signal going to the voice coil (for the subs). There are 4 of these modules, 1 mounted on each of the 4 subs.
I bought a pair of Pioneer component speakers (2-way), and went to wire them up. The only problem is on the Infinity speakers, there was a blue and white wire going to the speaker (which was the output of the power booster). Since the stock Chrysler Infinity speakers aren’t marked +/-, I am not sure what the blue and white wires stand for. I was thinking white was used as negative, but I know on Chevy's its opposite.
Does anyone know if the blue wire coming the power booster is used as a positive wire, or a negative wire?
Thanks, I can’t seem to find this simple answer anywhere.
Old Aug 31, 2006 | 02:19 PM
moe's Avatar
moe
Default RE: Wire Colors On Infinity Acoustic 10 System?
send me your email addy and ill send you a copy of the wiring i work gor chrysler.i couldn't post it to your forum .john
Old Sep 2, 2006 | 10:48 PM
neuronyx's Avatar
Hello John,
Thanks for offering your assistance. I sent you an e-mail with my e-mail address.
Tony.
Old Feb 22, 2010 | 09:04 PM
DamianBaker3's Avatar
Default im having the same problem
i am also having the same problem....i cut the pre amp off from the factory speakers to put new ones in...I put the black n white wires together n connected them to the (-) an i connected the red an yellow an put them to the (+) now only the front speakers work...what should i do about this prob...
Old Feb 22, 2010 | 09:38 PM
JD_2010_Sebring
Feb 2, 2012 12:21 AM
70JUDGE
Jul 31, 2009 07:24 AM
SebringOwner77
Apr 29, 2009 02:41 PM
izzyrider
13
Jul 8, 2008 05:25 PM
TigerFan
Dec 26, 2007 10:59 PM
