2008 sebring 2.0l cdr diesel
Old 01-27-2012, 10:16 AM
Big Wull's Avatar
Default 2008 sebring 2.0l cdr diesel
my sebring hesitates on acceleration then for some reason it will clear itself for a few weeks and runs great then the problem returns, sometimes when i go up hill the power drops and i struggle to reach 40mph. I have the vw passat engine. any ideas what the problem is?
Old 09-09-2013, 02:45 PM
stewey's Avatar
Have you got any warning lights on?
Old 03-09-2014, 11:29 AM
noragem's Avatar
is the power back to normal when you turn off and on again? same problem with mine but noone find any problem when it cuts the power(turbo) i m only turn off the car and straight on again back to normal until doin again
Old 04-08-2014, 03:12 PM
Big Wull's Avatar
Engine management light comes on only after five or six attempts at turning engine on and of then will go of again after a couple of hours normal running also noticed sudden burst of high heat coming through heaters just before and after power loss
Old 04-08-2014, 03:17 PM
Big Wull's Avatar
yes sometimes, will be ok for a week or more then sometimes full power will last a couple of mins
Old 07-28-2014, 03:40 AM
Leedsman's Avatar
Following the principle of "going for the easy things first" I would clean the injectors using only Forte' diesel injector cleaner poured into the fuel filter (injector cleaner doesn't work just poured in the tank, at least it never has for me). This is the first thing a diesel mechanic would do. Cost £12 to £14 for a tin of Forte'. It may or may not work, but at least you've not spent much money, or wasted much time. And you'll have clean injectors.
After that you can go for fuel starvation, pumps sucking in air as well as fuel due to cracked parts in the fuel system. The last VAG diesel I did was a shim-tappet 5cyl in an Audi 100, I have no further in-depth knowlege for that engine.
Leedsman.
Old 08-30-2014, 07:33 AM
noragem's Avatar
probably problem is green or brown turbo pipe.they look like a cable..
jordanuk
02-25-2015 01:19 AM
abdul123
07-21-2013 05:52 AM
Denis.V
02-05-2013 09:16 PM
alwal0307
05-01-2012 01:38 AM
canada
07-08-2006 02:09 AM
Quick Reply: 2008 sebring 2.0l cdr diesel
