Other Any other Chrysler within.
1994 Lebaron Questions
Old Jun 27, 2017 | 01:45 PM
OraDBAforPsoft's Avatar
Thumbs down 1994 Lebaron Questions
1) I want to flush the power steering fluid. Is there a reservoir? or am I supposed to suck it out the fill tube? I am familiar with the 'blood transfusion' method of using the reservoir in/out tubes to effectively replace all the power steering fluid, but cant find one on this car.
1a) The owners manual says 'do not use ATF' - Can I use generic Prestone Power Steering fluid?
2) Brake fluid fill cap/reservoir - I see there are 2 caps - is it divided up front/rear? or LF and RR on the one cap and RF and LR on the other?
2a) The manual says DOT3 fluid - anyone using DOT4?
3) Fuel filter - is this an in-line filter or integrated into the tank with the fuel pump? - Where do I find it and do I need special tools to replace it?
4) Fuel pump - is this a submersible pump inside the tank? If so, where do I access it - under the passenger seat etc?
Are there any DIY threads on this site that will answer these questions? I could not find any for the 94 v6 3.0L lebaron.
Thanks in advance
Old Jun 27, 2017 | 01:46 PM
Default sorry - thumbs down looked like a question mark
getting old and eyesight worse
jlakcarnut
Other
Sep 23, 2010 04:32 AM
jlakcarnut
Jul 16, 2008 09:04 AM
russ1960
Oct 21, 2007 09:05 PM
russ1960
Oct 21, 2007 08:50 PM
paintballproam
Other
Nov 26, 2005 07:23 PM
