Other Any other Chrysler within.
87 lebaron 2.5 rod bearings
Old 07-01-2013, 07:40 PM
Ray32825's Avatar
Default 87 lebaron 2.5 rod bearings
I just got a 87 Lebaron with a 2.5L (vin K) engine that has a rod noise amongst other things. I thought it best to fix the engine first b4 putting money into the AC and cooling system etc.
So, I jacked it up and removed the pan and carrier assembly and got the rod bearings off. All the bearings are worn/scoured and are stamped standard size. I was wondering if I should just replace the rod bearings with a standard set or should I check the main bearings as well?
The engine only has 80K miles on it, I cant understand why the rod bearings are bad in the first place - maybe the owner ran it low on oil or something. The journals seem ok, was wondering if I should measure the diameter on each to verify if they are true or just go ahead and slap on a new set of bearings and not worry about the mains or the oil pump etc.
Pics - http://i927.photobucket.com/albums/a...psa0944b0b.jpg
http://i927.photobucket.com/albums/a...psc4cb21e5.jpg
I will appreciate any help on the matter......
Thanks in advance,
Ray
jongie
02-13-2012 07:41 PM
wrenchpuller
10-02-2007 12:46 AM
peteats
05-03-2006 12:23 PM
peteats
05-02-2006 07:20 PM
Scruff76
03-23-2006 02:33 PM
Quick Reply: 87 lebaron 2.5 rod bearings
