93 5th Ave Heater fan and Headlights
Old Jan 30, 2008 | 06:47 PM
ExpressEN1's Avatar
Default 93 5th Ave Heater fan and Headlights
HELP 1-The heater fan only works on high where might the relay be located. 2-At night, when my headlights are on, they flicker off and on. The switch is pulled out . I don't use the auto headlight feature as it never turns the lights off and I end up with a dead battery. The only way to stop the flickering is to turn them off for a while. The head lamps have been replaced as well as the switch.The service manuals from the parts store is of no use. It's a real thrill when your headlights start to flicker when it's dark and some one pulls out in front of you because they think you are flashing your lights, telling them to go ahead. and once again HELP
Old Jan 30, 2008 | 07:02 PM
moe's Avatar
moe
Default RE: 93 5th Ave Heater fan and Headlights
you need blower resistor.as far as the lights if you don't a ground problem then you need a headlight switch
BillMarts
Mar 25, 2008 12:53 PM
jaydee79
Aug 25, 2007 11:52 AM
marshall13b
May 25, 2006 05:07 PM
marshall13b
May 19, 2006 04:19 PM
Lateralus
Other
Jul 4, 2005 08:40 AM
