02 300M 3.5L HO-OverHeating
Old Jun 2, 2019 | 08:20 AM
Burn59's Avatar
Angry 02 300M 3.5L HO-OverHeating
I have a 2002 300M 3.5L HO the other day it over heated to the red...I didn't notice till it set a code and dinged...
Luckily I was less than a half block from home...when I opened the hood ...I discovered a crack in the tank reservoir
spraying coolant...I got a replacement online changed it out and added some universal coolant less than half a gallon!
I did open the bleed valve while adding coolant it was a steady flow no bubbles, but now the car overheats under driving conditions very fast 10-15 minutes it's fine idling but driving it goes up past half quickly but if I crank the heat it comes back down to half, is there another issue or just air in the system
Old Jun 2, 2019 | 01:47 PM
prob warped the heads
Old Jun 3, 2019 | 05:41 AM
FIREM's Avatar
Heads and head gaskets are vert robust on the 3.5. Anyone that advises heads or gaskets first needs to learn how to properly troubleshoot and diagnose rather than throw parts>
Burn59
Jun 3, 2019 06:51 AM
Supermag
Nov 29, 2012 01:16 AM
deeyvonne
Sep 19, 2012 08:26 PM
Daryl Baines
Mar 17, 2008 07:36 PM
