1996 Chrysler Concer Lxi check engine misfire
There is an oil leak in my spark plug tube causing a misfire, and reduced fuel performance. I replaced the valve cover gaskets, but I didn’t know where to put the spark plug tube seal… where does it go? I put it under the nut that the spark plug wire goes on top of.
Okay I put the seal in the right place. That means the oil is coming up from the piston?! I’ve had the car for a while, but right after I got it I hit a hard hole in the road and smacked the bottom of my car on the ground. I think the check engine light for the misfire came after that…
I’m thinking the oil in the spark plug tube is blow by from the piston like a worn/damaged piston ring possibly from smacking the bottom of my car on the road. Whether or not smacking my car on the bottom of the road is the reason there is oil in my spark plug tube causing a misfire. I thought a compression test is what helps determine that. I haven’t done one before.
otherjohn
May 16, 2022 12:17 PM
