1996 Concorde water pump
Old Dec 21, 2022 | 12:56 AM
Criesler's Avatar
Default 1996 Concorde water pump
Do I need to replace timing belt if replacing water pump?
any tips or advice on changing water pump appreciated even recommending which water pump to buy.
Old Dec 21, 2022 | 09:30 AM
FIREM's Avatar
Is it a 3.3 or a 3.5 ?
3.3 is an external pump with a chain driven cam.
3.5 uses a Timing Belt to drive the cams and water pump and a new belt is a maintenance item so yes change it.
Although it is a non interference design it is recommended to change it. Later design 3.5's are interference engines and the belt MUST be replaced.
Old Dec 21, 2022 | 01:39 PM
Criesler's Avatar
3.5 227620 miles
Old Dec 21, 2022 | 04:15 PM
FIREM's Avatar
That belt owes you nothing, should have been replaced at least twice already.
Defiantly Replace it
Old Dec 21, 2022 | 05:12 PM
Criesler's Avatar
I might not have to replace water pump. I’m trying to solve why car is overheating. I added coolant, but I think it got air bubbles. I left radiator cap off, added coolant, and revved car. Coolant bubbled out of overflow. Loosened bleeder. Coolant went into system. Kept doing that over and over, but now it is overheating.
Old Feb 27, 2023 | 11:33 AM
fast400's Avatar
Head Gasket damaged
cathyboulais
Sep 10, 2022 11:06 AM
RichyRich001
Feb 8, 2018 08:27 PM
Joslin Carson
May 5, 2016 11:12 PM
Ryder
Oct 30, 2011 02:43 PM
zdrag
Nov 21, 2010 07:47 PM
