water pump
Old Sep 9, 2022 | 09:15 AM
cathyboulais's Avatar
Question water pump
I have a 2006, 300C, 5.7, the water pump isn't making noise or causing the car to overheat, but the car does have 200100 miles on it. Never really had any motor problems, but it's at the repair shop now for what he thinks is a leaky thermostat housing. I see where the water is being sprayed to, just not where it's coming from. The question is, should I go ahead and fix a water pump that is NOT broken?
Cathy
Old Sep 9, 2022 | 11:14 AM
tarhealcracker's Avatar
Cathy - I'm calling this a 50/50 proposition. Replacing the Water pump is a major step up from replacing the thermostat. On the other hand, if you plan to keep the car, go for it.
Old Sep 10, 2022 | 08:45 AM
Default Thank you.
Thank you for your help. I plan to keep the car until it falls apart, so I will be replacing the water pump.
Old Sep 10, 2022 | 11:06 AM
here is a video of my doing a hemi water pump the procedure is pretty much the same on all hemi 5.7 motors
RichyRich001
Feb 8, 2018 08:27 PM
Joslin Carson
May 5, 2016 11:12 PM
Ryder
Oct 30, 2011 02:43 PM
gbeach
Jul 11, 2008 09:15 PM
blathan
Other
Jul 12, 2006 08:14 PM
