1999 Concorde 3.2 Alternator removal
Old Sep 26, 2016 | 08:46 PM
Steel Skywalker's Avatar
Default 1999 Concorde 3.2 Alternator removal
Ok, so I have taken the belt off, the power cables from the alternator, the bottom alternator bolt and the brace bolt off, but the top alternator bolt is very long and hits the front of the car which keeps it from unscrewing completely so now I can't get the alternator out. What do I need to do?
Thanks in advance.
Old Sep 27, 2016 | 10:49 PM
IM assuming you have removed the upper radiator support? You can wiggle teh bolt past all that by moving the radiator back some.
Old Sep 29, 2016 | 05:14 PM
Thanks, I got the alternator in but still having the same issue. The engine will turn over, but will only occasionally start. I have also replaced the battery, spark plugs, valve gaskets and ignition coils. It is throwing two error codes P1294 and P1792. Is it possible that a vacuum leak will cause the car not to not start? If that's the case why does it start occasionally? Any thoughts? I was thinking maybe it was the fuel pump or injectors?
Old Sep 30, 2016 | 11:44 AM
what same issue is that?
Old Sep 30, 2016 | 11:51 AM
Old Sep 30, 2016 | 11:41 PM
fuel pressure test and a spark test se which one you are missing when it wont start. FYI an alternator has nothing to do with starting a car.
Old Sep 30, 2016 | 11:55 PM
How do I do a fuel pressure test?
Old Oct 1, 2016 | 08:42 AM
buy a fuel pressure gauges attach it to the por on teh side of the fuel rail start teh car see how much fuel pressure you have should be in the 55 psi range
Old Oct 4, 2016 | 11:01 AM
Ok, well I figured a few things out. The car will start if you disconnect the battery for about 10 min. and then reconnect the battery. After driving for awhile the check engine light comes on and it will still continue to start even with the check engine light on. It is only after the engine temperatures go back down the car needs another reset to start. Codes are P1294 and P1792.
Old Oct 4, 2016 | 09:30 PM
P1294-target
idle
not
reached
