1999 Concorde 3.2 Alternator removal
Old Oct 4, 2016 | 09:32 PM
Steel Skywalker's Avatar
Any ideas as to cause?
Old Oct 5, 2016 | 11:32 AM
The codes are for battery disconnect and the other is you have a vacuum leak some where
Old Oct 5, 2016 | 01:45 PM
FIREM's Avatar
P1294-target idle not reached, may be due to IAC issue. (Idle Air Control)
Has the throttle body/IAC ever been cleaned? May want to remove and clean both.
Sounds like it will start after the battery is disconnected. IAC auto resets once power is removed then adjusts as needed when running.
Will it start if you depress the gas slightly when starting? Another indicator that the throttle body needs cleaning.
Old Oct 5, 2016 | 02:29 PM
It does not start when pressing the gas down.
doubledsquared
Jun 30, 2018 01:34 AM
noasinc
Mar 29, 2014 08:57 PM
ghlkal
Oct 15, 2011 05:48 AM
Onlylexus
Dec 12, 2010 03:28 PM
toolmaker
Nov 23, 2008 09:35 AM
