1999 LHS bodyman question
Old Oct 24, 2011 | 03:29 PM
DaveyBoyLHS's Avatar
Default 1999 LHS bodyman question
Just bought mine a couple of weeks ago and I bought it with some minor damage to the right front fender and bumper and if it can be fixed by buying some used parts if I can find them the same color, I'd like to take care of it.
Most of the damageis right where the bumper cover and fender meet and I am assuming that since they bolt together there (from what I gather from a couple of YouTube videos) and that was what was damaged that they had to rig it with sheet metal screws and screwed right into the structure behind the actual parts.
I am at work right now and will post a pic when I get home if that might help.
Old Oct 27, 2011 | 04:16 PM
peshewa's Avatar
If you buy aftermarket replacements, they are usually primed but unpainted, the aftermarket parts also are slightly smaller than the originals. I used to do autobody & found this to be true many times. I usually had to add some body filler on the edges then finish sand to make up the gaps that werent there before. If you get good ones from a used vehicle, you are best off - even if the color does not match. If you are up north, that will be hard due to rust, but in the south it is not so hard. I used to live in Fort Worth Texas & there is a series of salvage parts suppliers called Heaven - dodge heaven, honda heaven etc, they sell good rust free body panels. If you can find the stuff from someone like them, that is best. Then all you need to do is have them painted to color match. They are held on mostly by plastic clips and some bolts.
steveg1978
Jul 20, 2014 10:53 PM
not_da_one
Mar 6, 2008 06:36 PM
amesvans
Dec 30, 2007 05:50 PM
froggyscike
Dec 14, 2006 02:36 AM
nick1770
Nov 22, 2006 05:39 PM
