1999 LHS no heat
Old Oct 5, 2008 | 05:41 PM
kentchris's Avatar
Default 1999 LHS no heat
I have a 1999 LHS with luke warm heat. I checked for codes, topped off coolant(not very low), blead air(only coolant came out). The first time this happened I put the temp down to low then back to high and I got heat. This is not the case any more. If I put the heat on high and auto the a/c icon comes on the display. I can here vent door move when switching from floor, dash, defrost.
Any help will be appreciated
Old Oct 5, 2008 | 07:34 PM
Iwant2playNOW's Avatar
Default RE: 1999 LHS no heat
I had the same problem on my 300M...it was the BLEND DOOR ACCUATOR...
Look back on previous posts to find the diagnostic procedure...you can run a test from the ATC module..it will display an error code.
Old Oct 5, 2008 | 10:20 PM
feel both heater lines into the fire wall both should be same temp if not clogged heater core.
Old Oct 6, 2008 | 06:38 PM
kentchris's Avatar
Iwant2playnow, I dont get any codes. Display flashes but if I hit any buttonit stops flashing.
Tech, I checked one before I posted. I will search for the other one and check it.
Thanks, Chris
Old Oct 6, 2008 | 10:59 PM
they are less then 1 inch from each other going into the fire wall.
allg32
Dec 23, 2013 10:59 PM
reyesraiders1
Nov 11, 2010 09:39 PM
simonda
Jan 3, 2010 02:44 PM
davet
Dec 19, 2007 04:18 PM
Screamineagle66
Mar 13, 2007 02:42 AM
