1999 LHS Wet floor
Old Feb 9, 2016 | 07:24 AM
mopardave's Avatar
Default 1999 LHS Wet floor
Pass side rear floor soppy wet. Thot it may be long weather $100.00 strip ( we had lots of rain). Replaced it, no help. Someone said AC drain tube stopped up. Got under car, removed the tube and inserted tube into drain hole and used wet/dry vacuum to such the water out and got nothing. Reversed process and blew air thru tube into the whatever it is. Nothing at all. No water came out. Seems as if water comes out and drains into pass frt and then collects intp pass rear and I have to vac out w/wet/dry vacuum. Any thoughts?
Old Feb 10, 2016 | 07:16 AM
chrysler1's Avatar
Just a thought, check your engine coolant level. Maybe heater radiator has leak.
Old Feb 11, 2016 | 07:03 AM
mopardave's Avatar
Default wet floor
Some locally had suggested that and I discounted it because there is no antifreeze odor inside the car. Perhaps I should look at that as a possibility but I have had no issues with having to add coolant. Thank you for taking your time to comment on my problem.
roger03105
Dec 13, 2023 11:28 AM
cwilliams35
Jul 28, 2011 10:53 AM
Rickashay
Nov 3, 2009 06:00 PM
JohnPA
Dec 28, 2008 04:17 PM
cbrjay
Mar 18, 2007 03:47 PM
