2005 Sebring Convertible Wet Passenger Floor
Old Jul 27, 2011 | 07:45 PM
cwilliams35's Avatar
Default 2005 Sebring Convertible Wet Passenger Floor
We have had wet passenger floors after a long drive and the A/C has been on. I have seen TSBs posted for a possible drain tube problem but I have been unable to find any photos representing the tube in question or adequate instructions to follow.
Can anyone help me out?
Old Jul 27, 2011 | 09:11 PM
The drain tube for an A/C system usually comes through the firewall, bends down and just ends. Every other hose and wire harness under there goes off somewhere else. The end of the tube is generally flattened to keep bugs out. If you can find the tube, try massaging it gently to break up and crush the leaves and bugs and dirt trapped in it. Hopefully the crud will fall out and the drain will open.
Old Jul 28, 2011 | 06:47 AM
Thanks dcotter I will try that. One more thing, the convertible top is pulling away from the rear window in one corner. As it is raining today in metro Detroit is there I can get to seal that?
Old Jul 28, 2011 | 10:53 AM
I have had some luck with Polyseamseal adhesive caulk available in a tube from Lowe's for a few dollars. Search the forum for that. Recently, after a couple of years, that has been failing, too. I have seen numerous good reports about Rhino glue. I think I'll try that next.
A good clean surface is always very important for glueing anything. No matter how well the glue sticks, if it's only sticking to dirt, as soon as the dirt unsticks, the joint fails.
roger03105
Dec 13, 2023 11:28 AM
tracyk
Sep 20, 2011 12:36 PM
Rickashay
Nov 3, 2009 06:00 PM
JohnPA
Dec 28, 2008 04:17 PM
nirah
Oct 1, 2007 06:18 PM
