2001 LHS Electrical (starting) problem
Old Nov 3, 2006 | 11:02 AM
mailmule's Avatar
Default 2001 LHS Electrical (starting) problem
Topic explains it. Every once in a while the damn thing just clicks when trying to start. Sometimes while driving, the headlights would flash on and off on there own as well. Well, now it won't start at all. Just clicks when I turn the key and try to start. I charged the battery to see if it was the problem, but I put a meter on it and has full 12-13 volts. Also, crazy stuff is happening. AC blower will go on by itself, CD player lights blink and silly stuff like that. I do have the extended warranty, but a $200 deductible applies. This doesn't sound like a battery issue to anyone does it? Or maybe a starter? I did get it running for a few minutes and tested the alternator and it tested ok, but after shutting it off, the same ole clicking again.
Any help would be appreciated.....
mailmule
Old Dec 14, 2006 | 08:02 AM
plxmmk's Avatar
Default RE: 2001 LHS Electrical (starting) problem
the same problem happend to me 4 monthes ago...
just like you.. i said it is not a battery problem and the battery was fully charged..
but one mechanic said...replace it and let us check that..
I did replaced the battery and every thing was gone..the problem was solved...thanks god.
wish you best
my car is concorde limited 2002
Old Dec 14, 2006 | 01:06 PM
Easy to solve with 2 questions. What kinda click do U hear fast clicks or one big CLICK when u try and start the car?? second question what CCA rates battery do u have min cca i would have in there would be 600cca
Old Dec 15, 2006 | 03:25 PM
plxmmk's Avatar
it was fast click..and the battery was 750 amp...so???
Old Dec 15, 2006 | 03:33 PM
yes fast click battery check the terminals for not being tight might haft to replace the terminals as well.
sarkady
Aug 20, 2012 09:45 PM
TRev
Jan 11, 2011 05:48 PM
train31
Jun 30, 2008 09:31 AM
tdcrash63
Mar 11, 2008 08:27 PM
mailmule
Dec 7, 2006 07:04 PM
