Electrical Problem After starting car
Old Aug 20, 2012 | 07:33 AM
sarkady's Avatar
Exclamation Electrical Problem After starting car
Good day,
I have an problam that after starting the car the AC, radio, windows, ABS, wipers etc are not working, but when I turn the car off, and only on the ignition everything works fine. When I start again all is off.
I have tried to change batry, put the spare ECM under the bumper, disconect the IOD fuse, but all no awail.
Any addvice is apreciated.
the car is a Pacifica FWD 2004, full option with DVD.
Thanx
Alex
Old Aug 20, 2012 | 07:55 AM
a pcm does not control anything with the wipers abs radio or windows so why would u change that out is well I duno.
I would be looking at something like a wire issue or the fuse box issue
Old Aug 20, 2012 | 08:04 AM
sarkady's Avatar
I just changed ECM because I had a spare from before. I have checked all the fuses in the engine bay area and all are OK, exept if there are some others inside the car that I am not awaere of.
Old Aug 20, 2012 | 09:45 PM
now is the point where u get a wire diagram and trace down the powers and ground to each item and see what is linked between them all
ktrent
Mar 30, 2012 06:33 PM
cuatro4lif
Feb 9, 2012 07:35 PM
TRev
Jan 11, 2011 05:48 PM
mailmule
Dec 15, 2006 03:33 PM
mailmule
Dec 7, 2006 07:04 PM
