2004 300M No Start
Old Feb 7, 2014 | 07:37 AM
vabear's Avatar
Default 2004 300M No Start
Grandson's 2004 and she died on the road. Got her towed home and OBD codes are 0562 and 700. I recognize codes, but she cranks and voltage at battery is 12.0VDC. i suspect a bad alternator but told GS to check for fuel flow to Throttle Body. Any other suggestions?
Old Feb 7, 2014 | 09:58 AM
an alternator has nothing to do with starting a car its only works when the car is running.
Old Feb 7, 2014 | 10:27 AM
FIREM's Avatar
0562 Lower Voltage output from the alt than expected
0700 Trans has a code that will require a reader to see.
Still should start if you have 12v at battery.
Check for fuel: Do you hear the pump run for a few seconds with key on.
Check ALL fuses: Dash panel and underhood (PCM is fused as is the ASD relay, "SSR" fuse is part of the Alt circiut)
Does it crank "normal" ?
Slow: Weak battery, poor connections at jump post, ground stud, and/or battery
Faster than normal: Has the timing belt been changed? 7 yrs/105k interval and if it slipped or broke will have bent valves/low compression/fast crank speed
Got Spark: Pull a coil and check
No Spark: Crankshaft sensor suspect, have seen them fail without codes causing no start.
Old Feb 7, 2014 | 12:26 PM
vabear's Avatar
Default No Start
Had GS check for fuel delivery. Had a CPS go on my neon and it would start, run for 10 min to 15 min and die, cool down and start again. She cranks normal, he said when it died the gas pedal went limp (told hm to look at throttle cable) and brake pedal went hard. Wil check the CPS.
Thanks.
Old Feb 8, 2014 | 09:32 AM
vabear's Avatar
Default No start
So We have fuel flow, replaced Crankshaft and Cam shaft sensors and still no start. +30F and we are outside. plus wind keeps blowing.
Old Feb 8, 2014 | 02:35 PM
check the timing belt then
Old Feb 8, 2014 | 06:18 PM
vabear's Avatar
Default No Start
The beat goes on. Hood now closed due to weather, pulled cable realease handle and cable broke (somewhere). Suggestions for reentry.
Old Feb 9, 2014 | 05:45 AM
FIREM's Avatar
Old Feb 9, 2014 | 06:07 PM
vabear's Avatar
Default No Start
Cable broken forward of firewall (of course) currently she is a Lawn Ornament.
Old Feb 9, 2014 | 10:54 PM
Long screw driver flat head U can get under the car and pop the hood release Iv done it
Calab
Dec 29, 2014 12:47 AM
gunmetal300m
Dec 3, 2007 10:50 AM
adammcbane
Oct 9, 2007 04:26 PM
parcou
Feb 8, 2007 09:32 PM
osman
Feb 20, 2006 09:10 PM
