2004 Concorde Electrical Problem
Old Apr 25, 2008 | 08:32 PM
gmullen's Avatar
Default 2004 Concorde Electrical Problem
I was trying to hard wire a radar detector to an "ignition on" wire in my overhead console. I identified a good ground and a hot wire & spliced a power cord into them. When I tried it, the radar detector would not come on. I had had problems with the female outlet on the detector before, so I tried to check to make sure that the ground wire was making contact. I had the ignition on & touched a test lead to the ignition switch and a ground area on the detector. Immediately the fan (I had it blowing) and the door open chime stopped. I turned the ignition key off (the car was not running). I started the car & it ran normally for 3 or 4 seconds then died. I tried it several more times with the same results. The overhead console is black, only the check oil light comes on when the ignition is turned on, and the climate control head unit appears to be functioning, but the blower does not come on. All other electronics (fuel pump, door locks, windows ...) are working. Please don't nominate me for the idiot of the year award - I have already volunteered for the job. Any advice would be appreciated.
Old Apr 25, 2008 | 11:38 PM
gmullen's Avatar
Default RE: 2004 Concorde Electrical Problem
I went back & checked my wiring. I got the ground & hot wires crossed on the radar detector plug. So what it amounts to is that I connected a hot wire from the overhead console to the exposed metal portion of the ignition switch. Does anyone have a clue what I may have screwed up?
Old Apr 26, 2008 | 10:06 AM
check al fuses first of all
Hardworkingmom
May 17, 2015 01:39 PM
ddugal2002
Nov 16, 2014 08:53 AM
ymitchell
Apr 29, 2009 09:36 PM
ncallese
Jan 12, 2008 05:09 PM
squire724
Dec 21, 2006 03:10 PM
