300M 2000 3.5 4 speed - tranns. shifting problem
Old Mar 15, 2007 | 04:04 AM
M300M's Avatar
Default 300M 2000 3.5 4 speed - tranns. shifting problem
After replacing the gear filter ( Mopar) and the fluid (ATF+4), the tranny shifting is fine but sometimeswhen slowing down the shifting is not normal ( droping to second gear anddoes not shift) until i restart trhe engine , then the shifting become good again.
odometer display showing P 1684 & P 0700
Any idea pls ??
Old Mar 15, 2007 | 10:54 PM
Default RE: 300M 2000 3.5 4 speed - tranns. shifting problem
the p700 code just tells u that u have a tranny code in the tranny computer Need a scanner that can get into that tranny computer
Old Mar 18, 2007 | 02:22 PM
M300M's Avatar
Thank you
The dealer told me about following code by the scanner
0731
1784
1776
1790
Could u clarify what it is mean?
Old Mar 18, 2007 | 03:39 PM
P0731-GEAR RATIO ERROR IN 1ST
P1784-LR PRESSURE SWITCH SENSE CIRCUIT
P1776-SOLENOID SWITCH VALVE LATCHED IN LR POSITION
P1790-FAULT IMMEDIATELY AFTER SHIFT
731 and 1790 are related 1784 and 1776 are as well may be 2 different probs with each set.
Gonna haft to have some one check it out and run the tests on it
possable valve body and speed sensors
Old Mar 20, 2007 | 01:12 PM
M300M's Avatar
Thanx for reply bro, The dealer recommend to replace the TCM & the valve body !! Does it make sence to you that changing of the Tranny filter can cos these problomes, Don't you think as a first step to ask the dealer to reset or flash the TCM first & what you recommend if this Doesn't work.
philjacq
Dec 14, 2012 01:05 PM
bdj5773
Aug 20, 2012 11:38 AM
fro919
14
Sep 25, 2010 12:46 PM
Toumane0
Jul 29, 2008 07:50 AM
Joe_B_
Mar 3, 2008 01:47 PM
