96 Chrysler LHS High Revving too hard when car warms up:Transmission or Engine issue?
Old Jan 10, 2011 | 09:52 PM
symphonic81's Avatar
Default 96 Chrysler LHS High Revving too hard when car warms up:Transmission or Engine issue?
I have a 96 Chrysler LHS and my automatic transmission slips, jerks, and MOST IMPORTANTLY, the car starts revving way too high (at relatively low speeds) once the car warms up. It feels like it will not shift into its proper gear when the car is warm (or at least that is how it feels). This ONLY happens WHEN THE CAR IS WARM! ALLOW ME TO EXPLAIN: If I let the car sit for a day then start it up and start driving while the car is still cold, I can go 85 MPH and the call will stay under 4,000 RPMS and drive smooth without any high revving. But as soon as the car gets warm, the engine revs over 6,000 RPMS just driving over 40 MPH!! its like the car will only operate in first gear when the car is warm... it won't do a natural shifting to the appropriate gear when the car is warm. I got my transmission rebuilt like 2 years ago and I doubt that is the issue, especially since I figure if it was a mehanical transmission issue, it wouldnt shift into its proper gears PERIOD, not just when it's warm! And just a week ago I flushed my transmission fluid and still no resolve. Im starting to think it may be a sensor issue but I don't know much about transmission sensors on a Chrysler LHS. Someone also told me that MAYBE it could be more of an issue with the ENGINE??? (havent changed the spark plugs in years). But would that explain why this only happens WHEN THE CAR GETS WARM??? IM REALLY TRYING TO FIGURE OUT IF THIS IS MORE OF A TRANSMISSION ISSUE OR MORE OF AN ENGINE ISSUE.... SOMEONE PLEASE HELP ME FIGURE OUT WHAT IS WRONG HERE!
--SYMPHONIC
Old Jan 12, 2011 | 09:21 AM
007's Avatar
007
--SYMPHONIC
You have answered your own question. The transmission is slipping when it warms up, nothing to do with the engine. Rebuilt two years ago, but still the problem. If the fluid is full, the filter clean, and you've already flushed it I'm afraid your off the transmission shop again. The transmission may be in the proper gear as you've described, but the clutch packs that engage those gears either have leaking seals or the clutches are worn out. The clutches are not fully engaging when warm and allowing slippage and high revs. Stop doing that before you damage the engine. No plugs, sensors or anything on the engine will fix the slip in the transmission. A sensor issue on the transmission will result in the execution of 'limp in; mode. You would have reverse and 2nd gear only. That doesn't appear to be the case by your description. I'm afraid you're off to the transmission shop again.
007.
Spiceman
May 11, 2012 10:44 PM
Walt-Aspen
Mar 7, 2012 11:59 AM
HrabiaMol
Jul 25, 2009 01:31 PM
sebringted48
Jun 7, 2009 04:27 PM
raj
Feb 14, 2009 10:49 AM
