98 Concorde doesnt run
Old Jan 23, 2009 | 04:51 PM
chriswest's Avatar
Default 98 Concorde doesnt run
anyone know what could be the problem, my 98 concorde just quit running, it will start for a few seconds then shut off. I had to use my aftermarket remote car starter to start it because turning the key wont make it run. when it does run, it bogs down completely to a stall when you press the gas pedal, any suggestions??
Old Jan 23, 2009 | 10:10 PM
Default RE: 98 Concorde doesnt run
what are the codes in the engine computer.
Old Jan 24, 2009 | 03:19 PM
chriswest's Avatar
How do I find out what the codes are? the car is stuck at a mall parking lot, went there this morning and unplugged the battery for 20 minutes, the only difference was that the "check engine" light did not come on while it ran for the 2 or 3 seconds that it does. as soon as I press the gas, it automatically kills the engine. I tried turning the key to "on" 3 times like I've been reading but the check engine light didn't do anything. I should note that there is an aftermarket car starter installed, its been flawless for 3 years though, but when the problem first happened, it was the only way the car would start, and when it first happened the car would actually run (unless you pressed the gas) and I was able to move it a few feet under its own idle, but now it won't run at all or at least for only a very few seconds
Old Jan 24, 2009 | 03:27 PM
chriswest's Avatar
Post ID: 24385
Old Mar 12, 2009 | 09:44 AM
dodger's Avatar
You need a OBD-2 code reader for about $50.
My 99 Concorde will also sometimes display codes on the odometer if the key is turned to 'on' a few times (5?) I stumbled onto this just by luck.
The codes are numbers like P0125. dodgeintrepid dot net is a good place to ask questions if you find yourself in a bind.
Old Mar 12, 2009 | 08:55 PM
by u unplugging the batt u erased any codes and hope of finding the prob with speed now U get to do it the hard way check for spark and fuel first.
ears18
Apr 24, 2015 10:36 PM
lilpengwen
Sep 11, 2009 02:37 PM
alparsalan
Feb 22, 2008 10:46 AM
powers84
Jan 6, 2008 05:50 PM
powers84
Jan 6, 2008 05:48 PM
