99 lhs gets hot while sitting
Old Sep 15, 2010 | 07:39 PM
99CHRYSLHS's Avatar
Question 99 lhs gets hot while sitting
Hello everyone! I just recently purchased a 99 Chrysler LHS from a private owner. I am only the third owner of this car as the last owner only had it for 8 months as it was only used for transportation to and from work. The issue that I am having is that the temperature climbs to almost the red while sitting in park for about a half hour. But when I get back onto the road and moving it cools down to just below half on the gauge. The previous owner replaced the thermostat and did a coolant flush on March 12th at 29,505 miles. It now has 35,400 on the odo. Any ideas? I do live in SW Florida and the temps here have been around 100 degrees!! Brutal. Thank You in Advance!
Old Sep 15, 2010 | 08:01 PM
TNtech's Avatar
I wonder if the cooling fans are not running and a 30 and a 40 amp fuse are blown in the PDC under the hood?
Old Sep 15, 2010 | 08:17 PM
99CHRYSLHS's Avatar
Thanks for the quick reply! I know when I start the car with a/c on I can here a fan running. Do Chrysler fans operate like Honda fans. With a/c off only one fan kicks on until temp goes up then the other kicks on and if you have the A/C on both fans run at same time. What do the 30 and 40 amp fuses operate? Do they run the fan motors? Thank You!
Old Sep 16, 2010 | 06:38 PM
TNtech's Avatar
No, they both run at LOW or HIGH speed. I've replaced a MOTHERLOAD of those fan motors. Yeah there is a 30A they can blow and sometimes they blow the 40A next to it that feeds the compressor clutch. There is also a high and low relay. The noise between speeds is noticeable so next time the gauge creeps up take a listen and look to so what's going on. Maybe run it in your driveway and observe and take notes. Let me know what you see.
The Jeep Cherokee has a fan system like youre talking about. I don't know of any other Chrysler product that has that.
Old Sep 17, 2010 | 02:31 PM
99CHRYSLHS's Avatar
Thank You for helping! You are VERY knowledgeable on these products! OK here is what I have found...... The drivers fan motor NEVER kicks on EVER!! I did check the fuses and found the 40amp popped so I replaced it. I started doing fuse swaps checking to see if the 30a was shot but it wasn't. I also swapped between the 3 relays in the PDC and it did not make a difference. The driver's side fan never kicked on. Is that the high speed fan or low speed? Sounds like I need a fan motor?
Old Sep 17, 2010 | 02:33 PM
99CHRYSLHS's Avatar
Oh yeah by the way the passenger fan does work!!
Old Sep 17, 2010 | 08:26 PM
stick your hand down there and move the fan I bet its locked up
Old Sep 18, 2010 | 05:15 PM
99CHRYSLHS's Avatar
Went and checked fan motor and it does spin by hand. Not locked up. Now I am really puzzled. Any ideas guys? Could it just be shorted out?
Old Sep 19, 2010 | 12:41 PM
TNtech's Avatar
BOTH fans have to work. They don't operate independently. They work together at 2 speeds. High and Low. Looks like you found your problem. Just because they turn by hand doesn't mean there is not an open inside the motor.
jcl_cls01
May 30, 2020 09:28 PM
Chrysler Forum Editor
May 21, 2014 03:35 PM
Exiled4Now
Other
Dec 1, 2013 09:41 AM
jalex
Cirrus & Breeze
Jun 3, 2007 06:16 PM
redriderbob
Dec 11, 2004 05:25 AM
