99 LHS Slow Oil Leak Driver Side.
Old Jan 20, 2014 | 11:19 AM
Chrysler_Guy13's Avatar
Post 99 LHS Slow Oil Leak Driver Side.
Hi Everyone,
I have Just noticed a slow oil leak coming from the front driver side of 99 LHS. I cannot track the leak and seems to only leak sporadically after the engine has been running. has anyone else encountered this problem, and know of a way to fix it? Any help would be greatly appreciated.
Thanks,
Dan
Old Jan 20, 2014 | 04:57 PM
simple need to look up there and see oil can be coming from any where lines block radiator so really just need to look and see what it is leaking.
Old Jan 20, 2014 | 04:58 PM
FIREM's Avatar
Could be a number of things located in that area.
Oil Filter ? Loose/recent oil change/double gasket?
3.5? Oil Pressure light sending unit right next to the filter ?
Oil Cooler supply fitting/line?
Need to get it up and look at it to pin point what is leaking...
Old Jan 20, 2014 | 05:24 PM
I did notice there was some leaking around one of the hoses that looked like it was heading into the radiator. I notice most of the leaking on the black ground effect that is located right under my bumper on the diver side. The Oil has not been changed recently, actually it is just about due for change, and have not had any oil pressure sensors come on. Does this sound more like a oil cooler supply line? Or something else. BTW thanks for all your help!
Old Jan 20, 2014 | 06:07 PM
FIREM's Avatar
Transmission and power steering cooling lines in the same area. What color is the leaking fluid? If red could be P/S or trans..
Old Jan 20, 2014 | 06:16 PM
The Fluid is black, I thought It could be the trans fluid, but I check that and it was normal, and the power steering looked normal too.
clambert
Apr 21, 2015 10:14 AM
mschaefe
Jan 20, 2013 05:39 AM
Stingray
Jul 24, 2011 07:51 PM
b_ron007
Dec 22, 2010 04:54 PM
jd6158
Jun 6, 2010 02:51 PM
