AC blowing max heat
Old Oct 27, 2014 | 05:00 PM
JimmyVeeDub's Avatar
Default AC blowing max heat
My air conditioning head unit in my 1995 Chrysler New Yorker is stuck off, Occasionally, like for a few minutes a month, it will run, but mostly the air conditioning/heating heat unit is off.
However, the blower motor is running at full blast and 90 degrees, which makes things very uncomfortable driving down the street. My usual solution is to pull the fuse for the blower, unfortunately I need the defroster this winter. Anyone have any similar problems?
Old Nov 24, 2014 | 10:50 PM
tx1drvr's Avatar
had the same problem with my 94 concorde. try putting the fuse back in and then undo the battery cable for about 10 minutes. Then hook battery back up and see if the atc resets. Also try hitting the panel on the right side of the console by the atc, it should quit blowing and then the temp numbers should light up, then turn off then back on to see if this fixes it. the atc panel in these cars was not worth a damn and you usually have to replace it. I had to replace mine to get it to stop.
RacingJunk
Apr 30, 2015 07:19 PM
cahines
Mar 13, 2012 08:13 PM
derty3456
Dec 30, 2011 01:20 PM
Braintrust
May 20, 2008 09:17 PM
Jon87transam
Aug 6, 2007 01:01 PM
