Ambient temperture sensor failure
Old Nov 15, 2014 | 02:36 PM
Dan Malone's Avatar
Default Ambient temperture sensor failure
Ok, so I have a 2000 300m that has no heat. The atc unit at first was dark, but found that wires on the back are loose. I ran the test and it came up with code 25 - "Ambient temperture sensor failure".
Here are my questions:
1. will this cause the no heat issue????
2. where the hell is the sensor located???
thanks
Dan
Old Nov 16, 2014 | 01:26 AM
no it will not it just outside temp that's all. Check for low coolant first
Old Nov 16, 2014 | 06:16 AM
Dan Malone's Avatar
coolant is up and car is running great, both heater hoses are warm, so I figure that the heater core is not plugged... Now I see that there is a small sensor near the fan switch, could that be blocked? Also the display panel does not show a temp, it only shows dashes.
Old Nov 16, 2014 | 11:59 AM
Dan Malone's Avatar
ok, this may be a little strange, but, I also had a check engine light on for P0442, so i changed the gas cap, and pulled off the neg terminal for a couple of minutes. When I put the cable back on, I now have heat and everything is working great. I ran the test again on the atc unit and now got codes 26 & 36, which I'm guessing because I had unplugged the atc unit(code 36) while the car was running, and having cleaned the in-car temp sensor. Does anyone have an idea how to clear them? or do they clear after some time?
Old Apr 26, 2020 | 09:25 AM
al62496@yahoo.com's Avatar
Default Cant find the ambient temperature sensor on my 2010 chrysler sebring
ive looked in front of the radiator by the front bumper, driver side and passenger and nothing. Its a 2010 chrysler sebring limited Someone HELP!!!
gr00vyd0
14
Aug 29, 2020 01:53 AM
Silverdel
Nov 3, 2014 05:38 AM
johnchrisr
Oct 10, 2014 01:19 PM
Stuart Irwin
Jul 16, 2013 10:02 AM
robwill
Mar 15, 2011 03:50 PM
