Bleeding my brakes
Old Feb 11, 2009 | 09:24 AM
donnyohs's Avatar
Default Bleeding my brakes
I was bleeding my brakes on my 1999 Chrysler 300M and everything went well until, I reached the front Drivers side Caliper..... I opened the bleeder screw and pumped, but no brake fluid came out.... I was wondering, what do you think could be the problem, and How would I fix it.... I think it might be a clogged brake line, or clogged caliper, if it is a clogged caliper, how do I fix it.
Old Feb 17, 2009 | 04:05 PM
DaveC8656's Avatar
sounds like the bleeder is clogged with dirt or rust. Try running a thin wire, like welding wire, down the hole to see if it will break loose. Otherwise, remove the bleeder screw and clean it out or replace it. That should do it. DaveC.
Old Feb 18, 2009 | 10:32 PM
shnormo's Avatar
make sure you didn't run the reservoir dry
Old Feb 19, 2009 | 08:14 AM
donnyohs's Avatar
The reservoir still has fluid in it, but I can't try to unclog my caliper yet until the weather gets warmer, since I live in Chicago and It just snowed, so I'm going to wait until it gets warmer. Also a noise comes from the brake pedal that sounds like air coming out, and I heard that its a symptom of a Brake booster going bad, is there anyway to determine if my brake booster is still working properly.
darkcild101
Mar 11, 2015 01:59 PM
cindy121087
Dec 4, 2013 02:02 PM
Lawdog
Oct 1, 2010 01:38 PM
xmanmta
Dec 22, 2008 06:08 PM
paul.siwek
Aug 10, 2007 01:26 PM
