Catalytic Converter Issue
Old Feb 11, 2012 | 09:57 PM
Kelmey's Avatar
Default Catalytic Converter Issue
Replaced a catalytic converter on my 2000 Chrysler 300m.
New to this forum and new to replacing catayltic converters. The joint between the CAT and the exhaust was leaking causing a loud noise. I searched on these forums and it appears this is common at this joint. The user said he welded the joint. Anyway, I was unaware of the possible welding fix so I went ahead and ordered a Magnaflow catalytic converter assembly from Amazon of all places, this one:
http://www.amazon.com/gp/product/B00...00_i00_details .
Seemed like a piece of cake. Had a little trouble installing and ended up replacing the o2 sensor since I was unable to get the old one loose. Got everything put back together and took it for a drive. Ran fine until a half mile down the road, it started making the "leaky muffler sound" and lost power. I figured the marmon clamp didn't hold. I managed to make it back home. It has an odd smell now and makes a rumbling noise. Everything seems to be tight. Does this need time to break in or did I purchase a non-compatible CAT? At a loss right now and will more than likely be taking it in for service, as I should have done in the first place. Thanks for reading...
pupy
Feb 23, 2012 01:54 AM
chrycon
May 24, 2011 01:54 PM
msarles1
Apr 16, 2011 10:27 AM
ymitchell7
Feb 6, 2011 04:45 PM
scfcarla
Feb 9, 2009 12:36 PM
