Chrysler LHS losing coolant
Old Jun 20, 2007 | 09:06 AM
luckilori226@yahoo.c's Avatar
Default Chrysler LHS losing coolant
I need some help with my Chrysler LHS-1997, I had some problems with the car overheating , we replace the water pump, the cap, fan sensor, and a relay. The car isnt over heating now, but I am losing the coolant, with no visable signs. I have to put water in it everyday. The engine is a 3.5. Cananyone help mewith this problem?
Old Jun 20, 2007 | 11:35 AM
Default RE: Chrysler LHS losing coolant
can u see the coolant any where in the engine area? or just gone?
oh one other thing was it leaking b4 u replaced the water pump and other stuff?
Old Jun 20, 2007 | 12:09 PM
You can not see any coolant on the engine, or on the ground. It holds the coolant if the car is not on, its disappears only after you drive it. It did not leak before the new water pump, we just assumed it was the water pump when the car was overheating. Could it be a blown head? Maybe I am filling the reservoir to full?
Old Jun 20, 2007 | 09:41 PM
if it was not leaking b4 hand and u replaced the water pump and u can see any leaking outside then yes u ahve a bad gasket. U can get a checker and see if the gas from the combustion chamber is leaking into teh coolant and u will know for sure that u have a head gasket leak. Or get a pressure tester and set the pressure to 18 lbs and see if it leaks or drops down.
Old Jun 21, 2007 | 08:32 AM
Thank you for all of your help but we seemed to find the problem. The radiator is leaking where the aluminum and the plastic meet. There is a small crack. I was told by a few shops that it cant be repaired, that it just needs a new radiator. True?
Old Jun 21, 2007 | 12:38 PM
Do you think stop leak would fix the problem? Or any other sealant out there?
Old Jun 21, 2007 | 04:40 PM
nope u do that and u will clog up more stuff and cause more trouble then it's worth thats my experence dealing with people bring there stuff in and the rad or water pump or t stat is clogged up
deanlee
Nov 28, 2013 09:04 AM
Clayton
Jun 7, 2010 08:19 PM
Mikestravels
Jan 17, 2010 04:08 PM
sjbilton
Apr 7, 2008 06:06 AM
Jun 20, 2007 12:09 PM
