Clicks once when starting...
Old May 20, 2014 | 10:07 AM
mschaefe's Avatar
Default Clicks once when starting...
I have a 2000 LHS with 84,000 miles. It was giffted to me from my grandfather. The other day I tried to start the car, turned the key, everything came on except when I turned it all the way I heard one click and the engine wouldn't start. Everything else was on. I thought it might be a battery issue but I thought it was weird that you didn't hear that constanct clicking that you normally do when you're batter is dead. Every time I would turn the key I heard one click and then nothing else. I kept turning it and turning it then finally after about 20 or 30 tries the car started. I've figured out that if I do it rapidly the car usually starts quicker with less turns the key than if I try to take my time. I'm pretty sure it's a starter problem but not sure if it's sign of bad relay or if I need a new starter. Any information or trouble shooting tips would be appreciated.
Thank you.
Old May 21, 2014 | 01:01 AM
Bad starter
Old May 21, 2014 | 03:44 PM
FIREM's Avatar
Bad Starter CONTACTS. These starters are very robust except for the contacts. For under $20. you can get a kit with contacts and plunger and save $$$
http://www.amazon.com/Victory-Lap-ND-34 ... B0031HMS7C
If I recall there are videos on youtube for the how to
Walt-Aspen
Mar 7, 2012 11:59 AM
Kubikus
Aug 23, 2011 10:02 PM
CRZRGUY
May 14, 2011 07:37 AM
tlray
Feb 24, 2011 06:30 AM
