Code P0430 "Catalyst System Low Efficiency Bank 2"
Old Jan 27, 2009 | 03:31 PM
Brandontw's Avatar
Default Code P0430 "Catalyst System Low Efficiency Bank 2"
Ok, i just got this car, and obviously this code is stopping me from getting the car smogged. the dealer i bought it from has his mechanic on the problem.
We have figured out that the code is caused by the downstream O2 sensor, probably due to faulty catalytic converter.
So i have a couple questions:
1. Which side of the car is bank 2? Drivers? Passenger?
2. He replaced the catalytic converter on the passengers side, and after a few miles, the engine light popped back up with the same P0430 code. Did the correct cat get replaced?
3. If it was the correct cat, i guess the next course of action would be to replace the offending o2 sensor.
4. If that doesn't work, what else could be causing the issue here?
Old Mar 24, 2009 | 03:45 PM
Sam99's Avatar
Default P0430 Catalyst System Efficiency Below Threshold (Bank 2)
I have the same problem on a 99 Concord. Please advise
Sam
Old Aug 20, 2009 | 09:37 AM
nuffer's Avatar
Default O2 sensor
Just fixed my 04 Concorde Lxi - replace the downstream O2 sensor on the passenger side. Easy fix and you can get a Bosch sensor # 13138 from Amazon.com for $45 free shipping
good Luck!
cyrone
Mar 24, 2011 11:39 PM
vb4921
Jul 31, 2009 09:58 PM
Sam99
Jul 6, 2009 10:39 PM
vb4921
Jul 5, 2009 09:57 PM
