Concorde LXI hood release cable
Old Jun 2, 2011 | 08:49 PM
mstjohn1974's Avatar
Default Concorde LXI hood release cable
Hey there,
I am wondering if someone of you might know how to pop the hood without the release cable? I appears that my release cable broke somewhere under the hood and not in the driving cabin.
Any idea how to do that?
thanks
Old Jun 2, 2011 | 11:16 PM
ShoyoasLXI's Avatar
depending on how the cable is run you can find it from underneath, cut it to expose the cable and pull the cut end with a pair of vice grips or pliers. you've gotta replace it anyway so cutting whats left shouldn't be an issue.
Old Jun 27, 2018 | 03:28 PM
GeraldB's Avatar
wedge the hood open until you can get a 1/2 inch or may need a 13 mm swivel socket because it is at an angle and take the latch bolts off, then get something to pull the latch off the studs, then you can pull the hood up. I had the same problem. This answer came from this site. It worked for me after trying all different things.
Old Jun 29, 2018 | 12:21 PM
long screw driver from the bottom and pop the latch like the hood cable would
Old Jul 26, 2018 | 01:25 AM
Moparista AS's Avatar
Dodaj you already fixed your problem? I've done emergency opening when my cable was broken, not too much space there, but as wrote, lie under a car, take some 0,5m long but thick stick and push the hood opening from down .I've done it from passenger side lied under car
Old Jul 28, 2018 | 09:40 AM
GeraldB's Avatar
thanks, I did get the hood open, have to replace cable, had to undo latch which was difficult
anwaypasible
Jun 22, 2019 05:07 PM
GeraldB
Jun 26, 2018 06:15 PM
aurora6408
Nov 6, 2010 02:39 PM
kungfumunki
Jun 21, 2007 12:32 PM
